Philco 116x
I am now the proud owner of a Philco 116x that was listed for sale on craigslist. Picked it up on Wednesday, it was only 10 miles from home and it was very nice meeting the seller who has a very nice collection of radios. Anyway, I replaced the filter caps and re-stuffed about half of the bakelite condenser blocks and brought it up slowly on the variac and it plays very nice already, even the shadow meter is working. Now to finish the recap and go through the resistors. I wanted to thank Ron, Terry, Jerry, and TA Forbes for there comments or I would have let it go.
Best regards, Paul
Icon_clap Icon_thumbup Congratulations! Icon_thumbup Icon_clap
Wow, that's great!!!!
Icon_thumbup
My pleasure!! Congrats!!
Great find and happy you got it. If only I was closer!Icon_biggrin You did well with a very nice radio.
Jerry
Philco 91 Tuning Condenser
