38-116 and 38-690 station tab source?
Does anyone here know of a good source for the station tabs for the 38-116 and 38-690?
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
OK, seeing no responses thus far, I'll modify my question. How much would you-all pay to get new ones? I amy have a custom printer here make some.
Speaking for myself, $10 to $20. Normally I would just say $10 but I know custom copies are usually not cheap.
I still have the 47-204 cabinet in an easy to find place, if you change your mind about wanting the escutcheon to make a mold. This is a long-needed project and I wish to state publicly that I am glad you've stepped up to the plate to make it happen.
I made my own for my Crosley. Just pick the right colors and print it on photo paper. Mine look great.
Eric
The Villages, FL
Eric, I think they are supposed to be translucent. Maybe Ron knows with certainty.
Yes, the originals were translucent as were the 1937-38 dial scales. Although, the amount of light produced by the lamps behind the call letter tabs was rather lacking, I think, in every 1937-38 Philco I've ever seen with Automatic Tuning. And Philco went from four lamps in 1937 to two in 1938, which only made the poorly lit tabs even harder to see.
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1374 online users. [Complete List]
» 3 Member(s) | 1371 Guest(s)
