early Fisher console
Have an early fisher console uses loctal tubes as well as minatures in fm tuner and 6l6 s in output asls has accessery scratch supressor and dynamic voulume expander chassis. very faint model 24 on nameplate. Need schematic, and info on what was the original reccord changer in it. Thanks for any help you can give Norman
There are currently 8393 online users. [Complete List]
» 1 Member(s) | 8392 Guest(s)
