Fairbanks Morse motorboating
I've been working on a 1936 Fairbanks Morse 72C2. I've done a complete recap as well as replacing all of the resisitors and some bad wires. I've also aligned the set and overall it's playing very well. the exception is when I reach the 800 to 900 Khz area. in this area the radio starts to motorboat loudly and the tuning eye pulses in brightness. Once I pass either side of this band the radio works normally again. It only does this on the broadcast band. Police and shortwave are unaffected. If I place my finger on the grid cap of the RF tube (6K7) the motorboating goes away and I can pull in a station in that area. Once I take my finger away the problem returns. I've tried switching tubes with no luck, anybody have any ideas? Thanks!
Kevin
Sounds like you need better bypassing of the RF stage. Double check the screen and plate bypass caps (maybe bad new ones) Also the lead dressing. Lead placement may be critical on this set. You can up the value of the bypass cap too to see if that helps. If your set uses metal tubes make sure that pin 1 is grounded at the socket.
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
There are currently 2924 online users. [Complete List]
» 2 Member(s) | 2922 Guest(s)
