General electric k-43 and RCA 100
hello, i have one radio GE k-43, i look for some pictures inside and some of the outside of the chassis , because i think that my radio have not some pieces.
I will buy one chassis of this radio.
my email is mauricioarancon@hotmail.com
thank you, Mauricio
