philco 42-1012
Murf, did you try to realign the set again. When I got my 42-400 first running, the volume was only about half of what it should be. The very first adjustment I made on it was at that #4 IF can,(first thing on the adjustment procedures), and lo and behold, that was it. (it was 99% tight, but that final 1% tightening did the trick- kind of strange that it worked full bore tight. All bands functioned normally). Not saying that is your problem, but a little food for thought, maybe.
Guess that is something I could check next time.
Thanks
Philco 89 indicator light.
46-1201 Trip Switch Spring
There are currently 8571 online users. [Complete List]
» 2 Member(s) | 8569 Guest(s)
