Help Philco 37-84 repair
Hello, friends.
I'm starting to repair my Philco 37-84.
I have a question, why is this black plastic piece that indicated in red in the picture?
[Image: https://dl.dropbox.com/u/7295556/PhilcoPartpost.JPG]
Those are capacitor blocks. There is data on them here: http://www.philcoradio.com/tech/blocks.htm and they are discussed at some length at http://www.philcorepairbench.com/capbuild.htm and here http://www.philcorepairbench.com/bblokcap.htm .
http://philcoradio.com/phorum/showthread...404&page=3
And here (and in other places) it is shown how to extract the innyrds without de-soldering and removing the block from the chassis.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
