40-165 Floor model $65
If anyone is interested there is a Philco floor model 40-165
for $65 located at the Red Mill Antiques near Bloomsburg, PA.
The cabinet is a little rough.
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Philco 91 Tuning Condenser
There are currently 3625 online users. [Complete List]
» 1 Member(s) | 3624 Guest(s)
