38-8 Tuning Cap assy removal
any special way to remove the tuning cap from a 38-8, looks like a weird slide on/off.
Thanks
I found the magic screw on the back.
Icon_thumbup
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
