41-295 I.F. harmonics across dial
That would be no problem, since there isn't anything either side of 1500. Thanks exray! I have to get a project off my bench, then I will try making a toroid coil and trimmer. How many turns of wire should I use on the toroid?
Use a -61 ferrite core. That's the most important. Can be any size. FT50-61 would be the minimum size (0.500 inches) , FT82-61 is a good compromise (0.82 inches).
Since we're only tuning one freq at the high end of the band use about 40-50 turns (not terribly critical) of small wire like 28 or 30 gauge. Use a 100pf trimmer cap for tuning.
Sounds good! There's a surplus store nearby that has those ferrite cores in bulk. And cheap!
Thanks again for all your help and advice!
Mike
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
