found parts!!
I just want to say thank you for all of everyones help in finding out what model my radio is and where to find parts! I found the face plate and knobs for under $40.00. I am pleased to say my hubby is also happy!! I will be getting an old t.v. from the family as well. I am asuming that I will have to join yet another forum for this? Does anyone have any ideas where to go for info? Again, thank you to everyone!!
mb
MB, congrats, glad we could help! Icon_smile We have a TV forum here, and our resident TV guru, Big Dave, would be glad to help you out in that regard, I'm sure. If your TV isn't a Philco, then feel free to ask about it in the "Old Ron's Bar & Grill" section. You don't have to join any other forum...we would rather you & hubby continue to visit us right here!
Philco 91 Tuning Condenser
There are currently 10179 online users. [Complete List]
» 3 Member(s) | 10176 Guest(s)
