5Y3 question
If you are going to use a fan, you can get one for nothing from an old computer power supply. They will run verty quietly on lower voltages, just use a diode, because they "eat" DC.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
There are currently 3199 online users. [Complete List]
» 4 Member(s) | 3195 Guest(s)
AvatarAvatarAvatarAvatar
