Any ideas what model?
Seller has no idea. Looks like someone took a 84B and stuck it in a console. Canadian version maybe?
Skip
37-33F
http://www.philcoradio.com/gallery/1937a.htm#b
Thanks. I think it is real plain.
I have that set in BG cabinet. It's a farm set that runs on batteries. With that being said it a good playing set. Push pull pentode output which will put out about 2 watts of audio. Would mind finding one but you don't find too many farm set here near Philly. My 37-33 came from a meet in Ky 25yrs ago
Philco 91 Tuning Condenser
There are currently 9807 online users. [Complete List]
» 1 Member(s) | 9806 Guest(s)
