Resistance Readings for Philco 118
Just acquired a Philco Model 118. (The version with the tombstone cabinet)
The chassis has 8 tubes and shadow meter tuning. It looks like everything is there.
Before I get too deep into this project I want to check all of the coils ,the power transformer, the audio transformer, 1st & 2nd I.F., and any other coil that I failed to mention.
That being said, I am looking on the Rider's schematic (Page 5-36) and I see there is no resistance values given for the parts I want to check.
Does anyone have a schematic or information that shows the proper resistance values?
Hi Kirk
Generally speaking you are looking things that have a pretty low resistances. If you see anything above 5K or so that part may be suspect. Most should be around a few hundred ohms if not lower.
Nice set!! Should be a GREAT player!! I think I've got the modern style console. Haven't fixed her up yet.
Ooh, very nice!jrblasde — 12:19 PM
I am picking up this radio today. The seller tells me it is all there and working.including the tuning eye. It has 13 tu...Dan Walker — 12:07 PM
Hi guys! I’m a new member here but have been using your resources for quite some time. Hopefully I can get some help wit...Radios1340 — 11:52 AM
There are currently 7606 online users. [Complete List]
» 2 Member(s) | 7604 Guest(s)
