Threads: 4
I am currently rebuilding the bakelite caps in my model 70. Cap #4989-E lists a 250 ohm resistor inside. Can I use a carbon film resistor to replace it or must I use a wirewound? Also, what wattage would this be and what tolerance? I have no 250 ohm resistors on hand but I do have a 270 ohm @ 1/2 watt . Would this be acceptable?
Only 2 more caps to do and one coil to be rewound - can't wait to see how it all works out.
![Icon_smile Icon_smile](https://philcoradio.com/phorum/images/smilies/icon_smile.gif)
I did have a bad output trans replaced with a universal. No reception I attributed to the bad coil. Radio was in pretty good shape considering it was a curbside find...
Threads: 55
City: Evanston, IL
1/2 watt carbon or carbon film resistors are fine to re-stuff in combo bakelite block condensers. Small cardboard carded wire resistors were used for their smallness and low values made the bundle smallish as well.
A 270 ohm will be fine. Still well under the 20% tolerance of the older resistors.
Threads: 4
Threads: 55
City: Evanston, IL
I believe I mention this in my
Re-Building page on my site for Bakelite Blocks.
Quote:"... Some of the Philco condensers also included a resistor (see chart). The original resistor is a small hank of light gauge resistance wire, in the required amount, wrapped inside a small kraft-paper wrapping. I assume from inspecting the size of the wire, that these resistors are rated at about a half-watt. Substituting a new carbon or carbon film half-watt part will work just fine."
