Looking for a supplier
Does anyone know of a cartridge and stylus supplier for vintage Philco 48-1201 record changer?
Mike
You might give these folks a try, they have parts for most phonos.
http://www.thevoiceofmusic.com/
Good call, Brenda. I can highly recommend them too. Gary has a wide selection of cartridges, and, while they may not have the exact same one as your original, will most certainly have something that will work. They DO have new exact replacement idler wheels for the 1201's. You might want to check yours, as 9 times out of 10, the rubber is cracked or warped (or both) which will adversely affect the speed of your turntable and sound quality of your records. Be careful with the little "jesus" clip that holds the idler on, though. VERY easy to lose.
I don't believe West-Tech rebuilds these type of cartridges, so you will probably have to go with a replacement. At least they told me they no longer rebult the type used on my 1948 Philco M-15 album length record player.
Here's another spot that offers cartridges I just happened across. Have no experience with them though. http://www.grandcanyontuberadio.com/index%202.htm
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
There are currently 2948 online users. [Complete List]
» 5 Member(s) | 2943 Guest(s)
AvatarAvatarAvatarAvatar
