Philco 40-190XF
Hi every one,
Up to my usual bad habit of perusing Craigslist and came across a Philco 40-190XF for sale not too far from me. It's in fair shape. Of course the pushbuttons are shot, but the dial glass looks good and the grille cloth is intact. the cabinet will need to be redone as well, I really don't need another project but I am digging the "Skyscraper" Art Deco cabinetIcon_lol! I'm going to go look at it on Friday evening. The seller is asking $100 for it, but I am thinking more along the lines of $75. Anyone have any opinions on this model set? I've never seen this style cabinet before, is it a uncommon model? Any thoughts would be great, Thanks!
Kevin
I have one and was just about to post about it! It is a beautiful piece of furniture.
Philco 91 Tuning Condenser
There are currently 9344 online users. [Complete List]
» 1 Member(s) | 9343 Guest(s)
