My Model 44 I'm Working On
I'm trying to do a cosmetic restoration of this set. I am wondering how to refinish the flaking toner from the edges of the top and on the feet. Any ideas?
[Image: http://i97.photobucket.com/albums/l213/u...5be170.jpg]
[Image: http://i97.photobucket.com/albums/l213/u...4dffe0.jpg]
Thanks.
In this case you might want to try the Howards Resto-a-Finish system.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3505 online users. [Complete List]
» 3 Member(s) | 3502 Guest(s)
