found 3 new toys
            hey guys what do you think of these a philco 41-255T , [not to bad of shape] a 38-3XX , and a 1935 16B tombstone [veneer on top needs redone are top an sides suposed to match front or what and did these have a piano finish it seems realy shiney i paid from 25$ to 28$ each for them david
I would have to say that you did VERY wellIcon_lolIcon_thumbup!! Especially with that 16B, which is one of the best radios Philco ever made. I also have a 16B but mine is in an earlier version cabinet. All of your finds are very nice and you sure can't beat those pricesIcon_lol. Congratulations.
Kevin
What a deal! Never find something like that further West. Great score.
Jerry
Well done!!!!!Icon_thumbupIcon_thumbup
There are currently 9877 online users. [Complete List]
» 2 Member(s) | 9875 Guest(s)
