Found My Philco Holy Grail!! A 201X
Today is a GREAT day! I found a Philco that I actually never thought would be possible to do. A 1935 201X! My avatar is a 200x which is what I saw on CL couple of years ago and didn't go after. I do like the cabinet on the 200x a lot, but the 201x has BOTH broadcast and shortwave, which is a big bonus in my eyes. Here is the baby just as I found it. The sound absorbing screen on the back got damaged in the move, but I have the pieces and I believe I can make it whole again.
Overall, the cabinet is is nice condition with some scratches, marks, etc. but I will first see how good I can make it look and then reassess. One can cap is gone, but I don't see that as a major issue. The dial scale is all there and intact as far as I can see. No hole in the speaker. I am really glad the grille cloth is available.
[Image: http://i1185.photobucket.com/albums/z345...50a56b.jpg]
[Image: http://i1185.photobucket.com/albums/z345...b506da.jpg]
[Image: http://i1185.photobucket.com/albums/z345...211abb.jpg]
http://i1185.photobucket.com/albums/z345...dd8ca0.jpg[/IMG][/URL]
[Image: http://i1185.photobucket.com/albums/z345...5f0277.jpg]
[Image: http://i1185.photobucket.com/albums/z345...2bb7b9.jpg]
[Image: http://i1185.photobucket.com/albums/z345...dd8ca0.jpg]
[Image: http://i1185.photobucket.com/albums/z345...32f125.jpg]
[Image: http://i1185.photobucket.com/albums/z345...eee1a0.jpg]
Gene
Congrats. on your find Gene. Looks like a great project with lots of potential.
A GREAT find. Considered the 1st Hi-Fidelity radio by Philco.
It will be the centerpiece of your collection once restored.
A very good find! Icon_biggrin
WOW, Gene, that's a great find!!!!
Definitely on my bucket list!!!!
Wow Gene good for you! It is always nice to find a radio that you can only hope to have in ones collection, and when one comes up we just can not believe it. I like the detailed woodwork on the cabinet. Good luck on your find and keep us up to date as to its comming along!
I had a 201X on loan from a collector friend for a year. I wanted to compare it side by side with a later Stromberg-Carlson with the "acoustic labyrinth" for audio quality (the 201X won hands down) but while I had it, I wanted to try improving its appearance. It had some deep scratches, even gouges, in the finish. But the basic finish was glass-smooth; you could shave in front of it. With a little dye in the scratches, they disappeared. From a few feet away all you could see were reflections of objects in the room, so the scratches and gouges weren't noticeable. I recommend putting some effort into cleaning and polishing, and I think you'll be happy with the result.
Thanks for the positive comments everyone!
Alan, I have been cleaning the case up, and I think the sides and upper portion will be ok even with some scratches. The front toned parts, especially on the bottom area have quite a bit of loss, so I may have to redo those areas.
I will say this is the ruggedest cabinet I have seen. Even with no chassis or speaker in it, this thing still weighs! It is built like a tank.
Gene
Beautiful radio Icon_thumbup
That's one I'd like to have but it's a very hard to find radio.
Philco 91 Tuning Condenser
There are currently 10156 online users. [Complete List]
» 3 Member(s) | 10153 Guest(s)
