Bakelite cap #'s can't find.
I'm working on a 16B and can't find restuff info on bakelite cap blocks 3615-AT or 3615-BL. Anyone have info on these? Thanks, Brett
Brett,
Looks like both were single .05 - 400V caps:
http://philcoradio.com/tech/images/bakelite.pdf
Carl
Northern Panhandle, WV
Carl,
Thanks for the help and the bulletin, I added it to my collection.
Brett
