Cap list for 40-190?
Anyone have a cap list for a 40-190? I've finally gotten around to recapping it but I can't find my SAMs on it
Full schematic can be found here:
http://www.nostalgiaair.org/Resources/339/M0013339.htm
Or a nice clean copy plus all available service data can be ordered from Chuck Schwark for $7. I recommend this. Icon_thumbup
FYI Sam's only goes back to 1946. Your Philco wouldn't be in it.
...and service bulletin #323 for this radio can be found here: http://www.audiophool.com/Philco.html
There are currently 7024 online users. [Complete List]
» 1 Member(s) | 7023 Guest(s)
