The dreaded "Silver Mica Disease"
Are you OK now? Opinions aside, we want the best possible outcome for each radio.
Thanks fox, I've always been OK. You see, I found the problem and I fixed it! The radio is now sitting in my kitchen and playing beautifully! And just remember, opinions are like... Icon_thumbup
Eric
The Villages, FL
