Restoration dial scale -Philco 620
HELLO, I HAVE A PHILCO MODEL 620 IN PROCESS OF RESTORATION, THE PROBLEM IS THAT THE DIAL´S SCALE IS TOTALLY ERASED. PLEASE IF SOMEONE WHO HAS A PHILCO 620 COULD TAKE A PICTURE OF THE DIAL AND SEND IT ME, I WOULD BE ABLE TO REPRODUCE IT USING COREL DRAW. THANKS IN ADVANCE I HOPE YOU CAN HELP!
MY REGARDS, ALDO
Please check your e-mail. Icon_smile
oK.-
Thanks and regards.-
Afiradio
Philco 91 Tuning Condenser
There are currently 10103 online users. [Complete List]
» 2 Member(s) | 10101 Guest(s)
