Philco 42-355, 395 dial cord diagram similar?
Is the dial cord string diagram for the model 42-395 similar to the routing of the string on the 42-355? I did a google search for a dial string diagram for the 355, and a post somewhere from 2004 mentioned that it was since there's no diagram for the 355.
Try this one: This has a diagram for the 42-355
Eric
The Villages, FL
Thanks, Eric.
Let us know if it works.
Eric
The Villages, FL
There are currently 10418 online users. [Complete List]
» 1 Member(s) | 10417 Guest(s)
