New and already smoking(literally)
#61
Glad to hear the tube fixed the problem! Amazing how something so simple can cause such mania. So often we look for and can spend hours tracking down the cause of a "dead set", and fail to look down at the disconnected power cord... Icon_wink
Tim
#62
Yes it is. I don't know what I would have done without this site.
Philco 91 Tuning Condenser
There are currently 10387 online users. [Complete List]
» 2 Member(s) | 10385 Guest(s)
