Cloth for Zenith Spinet - maybe Kenny knows.
These are few photos, the same piece of cloth, not sure which one is better so I put them all here.
This is the speaker cloth from the Zenith Spinet.
I wonder if anyone knows of someone who makes this pattern.
Kenny, do you?
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3525 online users. [Complete List]
» 3 Member(s) | 3522 Guest(s)
