RCA Advertising Display Radio
Funny, I sommetimes get stuff sooner from China than Canada but Just Radios is as reliable as they come. Many of us just keep 400 or 450 volt electrolytics and 630 volt mylars because they usually are small and good enough for just about any replacement, and are only pennies more.
There was one that sold for about $200 recently. I was gonna buy it but it was too expensive for me.
Good luck with the resto
Kirk
