Blue Tape, Grrrrr
You're right Ron, I hadn't.
The light adhesion tape I mentioned seeing on Lowe's website is Frog Tape. Thanks for the recommendation. Will definitely use it next time.
Thanks!
+ 1 on the Frog tape (green)
Art
Yes, as I said earlier masking tape seems to work fine.
I take it off right away to avoid problems. Many tapes get a stronger bond after just a few hours. Sometimes I warm it lightly so it peels off easy.
The blue tape is the only tape I have had problems with, I think it's for latex paint and nothing else. Lacquer seems to go through the blue tape and react with the glue.
Eico 232 VTVM Schematic
There are currently 10334 online users. [Complete List]
» 1 Member(s) | 10333 Guest(s)
