37-116 and 118
Well,
have just return from the trip to Hartford area where I
1) picked up 37-116 (the one that is going to Ukraine) or $175, and
2) 118, the same one I was denied the sale of first.The price came out to be 160.
Photos later, I haven't eaten since I had breakfast 8am.
I am happy that the guy decided that you were good enough to buy it from him.
Yeah, I am much better in person than in my emails, Kirk can attest to that Icon_mrgreen
And thick Russian accent helps. It is cute.
Wow .... I look forward to the photo ...Icon_thumbup
I can show it to ya 'morrow morn, if you pick up Skype call about 2 pm your time.
2am .... So this stuff. For your favorite receiver is ready for such a small sacrifice ... I hope that Google translator correctly translated my positive emotions ...
No it did not.
Anyway, will show it to you tomorrow.
Now we'll have to figure out hot to get ot to you.
Ain't gonna be cheap, I could tell.
Will need to ask a UPS store to pack it, it is above my abilities.
And buy a piece of plywood to screw to the bottom of the chassis.
Will probably leave the speaker and clarifiers in the cabinet.
I will also take off the dial and the band light indicator wheel, put it ia a padded envelope and tape it inside the cabinet.
Bought the chevron cloth from Kenny.
He promised to throw in two smaller pieces with centered center-line for the clarifiers.
Soon as it comes, I will ship the radio.
