Philco 3650
I had an opportunity to pick-up a Philco 3650 the other day.
Is there any difference between it and the 650 except for being built in Canada?
thanks
RoyG
Same thing just made in Canada! EH
Gregb
There are currently 5454 online users. [Complete List]
» 1 Member(s) | 5453 Guest(s)
