38-62 dial repair
I'm working on my first Philco and need a little (for now) help. The dial has a crack that I would like to repair. A previous owner tried, but to no avail. I've attached a photo.
Also, is there a way to possibly lighten the dial up a little and flatten it out some?
Thank you very much.
Hi Kirby
Reproduction dial scale available from Radiodaze
http://www.radiodaze.com/product/14172.aspx
Tim
Thank you.
There are currently 8977 online users. [Complete List]
» 1 Member(s) | 8976 Guest(s)
