Weekend sound on 38-116xx
On this long thanksgiving weekend i found time to RnR a little and cranked up the Philco 38-116xx . KAAM radio 770 am was playing some good music as always and had the house raddling with the power this set has.
Rock On . . . !
The Other Philco Guy
Nice!
Crist
Very nice indeed!
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
