Propeller dial for Zenith Y-825
I need a propeller dial pointer for a Zenith Y-825 table radio (with a strap for portability). This radio is a quite common type that Zenith produced from about 1951 to 1956. A picture can be found on the Antique Radio Attic website in their archives. The dial pointer for all of these radios look alike. However, they are not the same. The shafts are not the same length. The pointer I need has a 1 1/4" shaft.
There are currently 10793 online users. [Complete List]
» 2 Member(s) | 10791 Guest(s)
