need help diagnosing philco 60 issue
I was adjusting the tuning dial (it was a little off position) and some how knocked off my entire signal recieving capability.All my 60 (code 122) does now is emit a rushing (white noise) sound . The volume of it can not be controled by the volume knob.I had it turned on its side while i was woring on it, and i dont know if maybee i crossed a wire and blew out a cap or did something much worse.
I could really use some help here.
thankyou
Since the volume control doesn't work, look at the components after it in the schematic. Try replacing the tubes if you have spares, especially the 75 and the 42. The elements inside could have shorted while on their sides with power applied.
Dave
Colo Spgs
thankyou, i had no idea that could happen, will try that ,hopefully it will work
i did what you said and it worked!!!! thanks!!!!
Glad to help, and good thing it wasn't more complicated than a shorted tube. The 60 is an attractive radio, someday I'd like to find one in restorable shape.
Dave
Colo Spgs
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
