model 48 - 1253
I just got this set plays great . But going to go ahead & recap . was wondering wher could i get phono needle at .
Does this set play 33 1/3 records. For a 62 year old set looks new.
Thanks Denver Icon_biggrin
Hi
If your 48-1253 has its original phonograph, then no, it will not play 33-1/3 rpm records - only 78 rpm records.
Needles and styli may be found at West-Tech Services and Garage'A Records. Links on my site's Resources page:
http://www.philcoradio.com/resource.htm
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
