Trying to figure the production run on a 620B
Hey guys,
Getting ready to perform an electrical restoration on a 1935-1936 Philco Model 620B.  I am really having a troubled time trying to figure out the production run number.
The tag is below.  It looks like 1 - 4 but I don't really know what that means.
Thanks for the help.
Jon
"A Minute of Care is Worth an Hour of Repair" circa 1930.
That's the cabinet tag info, not the Run Number for the chassis.
Chassis production run number should be ink-stamped on top of
the chassis and is the left-hand number in the rectangle.
Could also be stamped on chassis rear apron.
Chuck
I understand Chuck. Thanks for the correction.
I have looked everywhere on the chassis and am not able to locate the ink stamp. Perhaps it has worn off over the years. A repairman has already been into the set ages ago from what I can tell.
I am just trying to figure out if this chassis is after run number 7 so I can use the correct schematic. From what I can already tell, the newer style three section wire wound resistor is in this set, so most likely it is a run number 7 or later.
Well you're in luck.  Service Bulletin 218-A, for the later production runs of the 620,
beginning with Run No. 7, shows the circuit you have with the 3-section resistor
in the power supply section.
Happy Holidays!
Thanks Chuck, I have your literature for this restoration!
Jon
   You have to also look at the layout of the Bake-o-lte blocks,,also,,,--it took me a time to figure that all out,,Resistor wire wound bolted to chassis has different Ohms...
Philco 89 indicator light.
