any help with this chassis number ?
hey guys looking for chassis model or year
[Image: http://i1303.photobucket.com/albums/ag14...zzkpci.jpg]
[Image: http://i1303.photobucket.com/albums/ag14...hqbeaz.jpg]   [Image: http://i1303.photobucket.com/albums/ag14...enxeba.jpg]   [Image: http://i1303.photobucket.com/albums/ag14...6yus9t.jpg]
thanks me
(12-21-2015, 02:20 PM)sam Wrote:  hey guys looking for chassis model or year
thanks me
Hi Sam,
Looks like a 37-XXX or 38-XXX.Six tubes for 1937 and 6A8 and 2x 6K7 I'd say 37-620, 37-630 or 38-620:
http://www.philcorepairbench.com/tube/tcomp4.htm
http://www.philcorepairbench.com/tube/tcomp5.htm
If you can see the electrolytic part numbers and/or dial number we could probably be 100% sure by looking at the parts list.
-Nathan
As Nathan pointed out, it is most likely a 37-620. It isn't a 37-630 as there is no evidence of a wiring harness for a shadow meter.
thanks guys
back in storage for later usage
sam
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
