Zenith 12s-265 console
Guys ....Would want to know. Tell me about this radio, good player? I know it is the easiest to find of the 12 tube consoles, but is it a good player? And who has one in their collection? I am able to grab one and would like to know if it would be a good one to add to the collection. It has been ofered to be once before. Thanks for the info.
All these Z consoles with lattice dials are very, very good players. Not that there aren't better ones, but these acoustically are excellent.
The zenith 12s265 is a very good radio, the 262 is the more common set. The cabinet style is very nice looking with the defferent wood veneers . I have one and am glad to have purchased it, I think you would be happy with it if the price is wright. 12s265 on far right in picture.
(12-22-2015, 10:58 PM)Frederick W. Taylor Wrote:  ......... I think you would be happy with it if the price is wright.
+1
It is the exact same chassis that is in all of the 12 tube 1938 models.
I don't know for sure but I think there all the same chassis on the 12 toobers and when i said the 262 is the more common , that's a 10 toober not a 12, my mistake.
(12-22-2015, 11:17 PM)Frederick W. Taylor Wrote:  ......when i said the 262 is the more common , that's a 10 toober not a 12, my mistake.
Actually the 9-S-262 is a 9 tube set, but even it is a pretty good performer.
 Like all brand Z AC operated models from the late 1930s and early 1940s it would be best to test out the power transformer first before buying, so bring your Ohmmeter and Ohm out the transformer windings at the rectifier tube socket. Brand Z had a nasty habit of using the same size power transformer in a 12 tube set that Philco would have used in a 7 or 8 tuber, it does not mean that they will all burn up but it does mean that there isn't much room for failure either if the set was powered up and run with leaky caps in it not to mention a dead short.
Yes, in the late '30s Z sets did have a small-ish power xfrmr. And they do get pretty warm if the set is played for a long time.
The speaker table error?
Philco 70 antenna lead
There are currently 6304 online users. [Complete List]
» 2 Member(s) | 6302 Guest(s)
