Philco Repair Bench on vacation
To All,
Starting next Monday, the 21st., I'll be on vacation.
Will be back Jan 4th. for biz as usual to resume order processing.
Will try to check emails, depending on my accessibility.
Chuck Schwark
The Philco Repair Bench
Chuck, you have a great vacation Icon_clap Icon_clap Icon_clap
M R Radios   C M Tubes
Ditto
Crist
Thanks Guys.
A little de-tox is in order.
Chuck
   Forget  ABOUT it,,,have a gGreat time
Have a great vacation, Chuck!!
Stuff has waited 70 years, what's a month or two?
Happy New Year, Chuck. Hope you're enjoying a well-deserved vacation.
1 - 0v - correct 2 - 0v - correct 3 - 0v - --------------------- both 3 and 4 should be the same. Check L2 for being o...morzh — 05:15 PM
