39/44 Tubes
Is the 39/44 tube a replacement for the type 44 used in early 30's Philco sets?
73 de,
Gary/N9VU
Yes.
The 39/44 replaces both the 39 and the 44. Icon_smile
Many thanks for that info, Ron. I hope all is well on your end. It's been awhile since I've run into you.
73 de,
Gary/N9VU
You're quite welcome, my friend; I hope all is well with you also. Icon_smile
