Escutcheon for Model 42-358?
Hello, I'm wondering if there is a resource for the plastic escutcheon/faceplate for a Model 42-358 console. I haven't found anything online.
Dave
There isn't...sorry. Your only recourse is to find a junk set with a halfway decent escutcheon. They will all have warpage to a greater or less degree, thanks to the Tenite which was used then.
As 3D printing becomes more common, the time may come when these can be easily reproduced...
Shoot. Thanks for your answer.
Dave
There are currently 10294 online users. [Complete List]
» 2 Member(s) | 10292 Guest(s)
