Threads: 1
City: Jackson NJ USA
Hi All,
New member- first time poster.
I have a model 81 that I have rebuilt. Replaced all caps, resistors and rewound the ant coil (primary side).
The speaker cone is in bad shape but it plays.
The set is working and I can get a local station in my basement- so I am not too far from finished.
I have been making voltage measurements on the tubes to confirm everything is in spec and I am having a problem reconciling the 42 output tube with the rider voltage chart for this radio. Specifically, the control grid CG to cathode K. The rider manual calls for 2.3 V. The 42 tube data sheet calls for a control grid voltage of -16.5 to -20 v. I am measuring about -17 v from CG to K (ground). Not sure if I have a problem or not.
My plate, screen and filament voltages are in spec. (riders chart).
thanks for the help,
Anthony
Threads: 11
City: Bellmawr, NJ
I say ,,,you are in the range between -16.5 to -20,,,sounds good to me
Threads: 271
City: Wilsonville
State, Province, Country: OR
Welcome to the Phorum!
If its playing well the voltage reading seems good to me. An alignment might be helpful as well.
Threads: 416
City: Boston
Anthony, you live in the same town as one of our members, Morzh! Good luck and welcome to the land of Philco.
paul
Threads: 566
Tony
Where in Jackson are you?
Threads: 54
Perhaps it was an error? The control grid voltage should never be positive on any audio output tube that I know of, maybe it was supposed to be -23 volts rather then 2.3 volts? If it was actually 2.3 volts the output would sound like garbage if it worked at all.
Threads: 1
(01-20-2016, 10:56 PM)morzh Wrote: Tony
Hi Morzh,
I am on Autumn Avenue, between Diamond and Cobain roads. About 3 minutes from the Justice complex.
Threads: 1
Thanks for the help!
It does need an alignment (IF and the dial). Unfortunetly, the dial is brittle and in alot of little pieces. I ordered a replica replacement. When that comes in I should be able to do the dial and other alignments.
Yes, I'm in Jackson- near diamond road about 3 minutes form the Justice complex.
Also, I used to attend the NJARC meetings in Freehold with my grandfather until they moved to Princeton and Wall.
thanks again,
Anthony
Threads: 566
Not too far, 6 minutes maybe. I am in a development by St Aloisius church, on Bennets Mills.
Threads: 1
(01-21-2016, 08:46 PM)morzh Wrote: Not too far, 6 minutes maybe. I am in a development by St Aloisius church, on Bennets Mills.
Yes, I know that area. My Kids went to St. Al's.
-Anthony
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
RCA T62 is playing.....
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
I forgot how the pointer is formed: could you show the way it is formed and how you tried to change it?morzh — 07:01 PM |
Was that pole piece left handed ?
Since the metal "spider" is toast, wonder if you can either get the "4...MrFixr55 — 06:54 PM |
Thank you Rod.
Hello MrFixr55. Thank you for the long reply. My radio is the 121 version (1 speaker) and I am aware ...dconant — 06:36 PM |
Your 8 watt transformer is good, the 42s produce 6 watts and you won't be sending maximum volume to the speaker anyway. ...RodB — 05:54 PM |
There are currently 2788 online users. [Complete List] » 2 Member(s) | 2786 Guest(s)
