RCA 28X5
I picked up an RCA 28X5 in restorable shape yesterday, and was wondering if anyone would be able to send pics of the decals used on this radio, the bottom label that shows the model #, and tube placement, and the label on the antenna loop that shows the pushbutton frequency ranges. THANKS!
There are currently 10306 online users. [Complete List]
» 2 Member(s) | 10304 Guest(s)
