BIG SCOTT CONSOLE CABINET RESTORE
Threads: 147
City: Dallas, TX
Threads: 147
City: Dallas, TX
Threads: 22
City: Waxahachie, TX
That will look great when you're done with it Fred!
Crist
I love the Scott Tasman cabinet - I think it is one of Scott's best looking sets. I probably should have held on to the AW 23 and Tasman that I had. Oh well, maybe after retirement, I'll pursue another....
Anyway, Fred, I am sure you will do your usual fine work with this one!
Threads: 147
City: Dallas, TX
Threads: 147
City: Dallas, TX
Threads: 104
City: Calgary, AB, CA
Very nice Fred. I always like to see your work. I have not used the Mohawk grain filler.
I have used the kind that you spread on with flat spreader and wait until it is almost dry, then use the burlap.
is Mohawk similar in application?
Dan in Calgary.
Living in Calgary Alberta
Threads: 147
City: Dallas, TX
Hello Dan, I quess Mohawk is about the same in regards to application . I wipe it off with fresh burlap before it dries hard like wax a car. I let it haze over then wipe it smooth, then later sand it off with 240 after it has dried overnight, clean and smooth out the crevices as show in pictures, that also before it gets hard.
Threads: 310
City: Kings Park NY
It looks terrible!
I will surely take it off your hands
You will have to show me how you did the veneer. Veneer on large areas scares me....
Me
AC: 4 DC: 1
Threads: 147
City: Dallas, TX
Threads: 69
City: Kansas city, MO.
Threads: 147
City: Dallas, TX
Threads: 22
You are truly a craftsmen!
Crist
Threads: 214
City: Seattle
State, Province, Country: WA
Stunning! Thank you for all of the photos.
Threads: 114
City: Sneedville, TN
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
