repairing light sockets
Hi Guy's,
I know I have read a n article Ron put on here about repairing Philco light sockets, but I can't find it.
I have a 37-116 that I need to replace or repair light sockets on.
Mine is missing the original light sockets and wire harness.
I managed to find a couple light sockets with the shields that need to be re-built.
Can someone supply me with a link?
murf
Philcoradio.com - Tech Section - Pilot Lamp Rebuilding
Couldn't post clickable link.
here
http://www.philcoradio.com/tech/lamps.htm
sam
(02-06-2016, 01:16 PM)sam Wrote:  here
sam
Thanks Sam and Mike.
murf
  If you could find some phenolic or porcelain washers of a suitable size that would be an improvement over the nylon ones, although all are better then the rubber crap Philco used.
Restoring Philco 96
There are currently 5368 online users. [Complete List]
» 4 Member(s) | 5364 Guest(s)
AvatarAvatarAvatarAvatar
