Can someone ID this Emerson Radio?
Need the model info for this radio. Picture is of the cabinet. Chassis is on the bench. Thanks for any help!
From the Stein book looks like model 146 ten tubes, 3 bands. Your picture does not show the base.
Hi;
Please post a picture of the chassis and what tubes the set has, it will help narrow it down enormously.
Best Regards
Perhaps it is a console version of the Emerson mod 140 large wood tabletop with same chassis( 1937)? Radio Attic has 4-photos, one with chassis view, of the mod 140,w same number of knobs/shafts, & placement thru cabinet openings. Same shape dial escutcheon, & exact eye-tube escutcheon also. Many mfgrs of that era used the same chassis in different cabinets designs.It looks very similar, & worth a look anyways. Heres a link to compare photos with your chassis on your workbench, just in case it is a match?:
http://www.radioatticarchives.com/radio.htm?radio=8183
There are currently 9951 online users. [Complete List]
» 2 Member(s) | 9949 Guest(s)
