philco 116b dial drive rebuild
 Just starting on the 116B. While waiting on schematics I ordered yesterday from Chuck. I thought I would look at removing dial drive assembly. No pics yet, just wanted to thank Ron for the tech. section on how to disassemble the 116 dial drive. It saved me a lot of time. Thanks Icon_clap
I appreciate that, Mike...but you really should thank Phorum member rghines1 for providing the info and photographs. All I did was to post them online. Icon_smile
 You are right. Thank you Richard Hines for the detailed pictures of the 116b dial drive rebuild. Icon_clap
