Fisher 210-T
I just got one of these and I want to test it. I cant without a speaker right?
Me
Transistor....depends, in general yes you can but better with the load.
Again, was it recently gone through? It is and old piece, might need recapping etc
Nice! Icon_thumbup
If you have a set of stereo headphones with a 1/4 inch plug you can use those in lieu of speakers. Or if you have headphones with the 1/8 inch plug and a 1/8 to 1/4 plug adapter, that will work also.
Ok cool, I actually don't own any headphones Icon_eek
What is todays market value on this?
I was researching and didn't find much...
Me
I'd say less than $100. It is one of the low end models in their lineup. It's from 1970...hifiengine sez 32 watts per channel, which surprises me - I expected it to be lower, more like the 175-T (18 watts per channel).
http://www.hifiengine.com/manual_library...10-t.shtml
Of course, if you want to dump this at Kutztown, I promise to give it a good home. Icon_wink
Seriously, I have a 220-T from 1966, which is somewhat similar to the 210-T. It's a very nice receiver and I am currently using it at my desk in my home office.
There are currently 8576 online users. [Complete List]
» 1 Member(s) | 8575 Guest(s)
