Zenith 6C05Z production change 3 ???
           I though if you BUY a schematic for a radio ,TV,,,,that you would get the Production Change Bulletin #3 with it,,(DIDN'T  KNOW THERE IS ONE) ( and still don't have it) this little set is becoming a pain in the butt,,, I got A  extra resistor in it and jumpers on 2 tubes ,,,for some reason ,,smarter than I can figure out,,,and don't have, the true reading (ohms) for this resistor,,it measures 139.6 ohms,,WHO KNOWS,---,it pertains to 35L6GT,,,on the Chassis, it has pin 6 ---87volts with resistor 139.6 ohms going to Pin 4--instead of the 87 volts going to Pin 4-----then 12SQ7GT,,they have a jump that goes from Pin 3 to Pin 5 and to Pin8,,, SOO,,this little set worked Very well,,, Changing out Paper capacitors ,resistors ,and 2 tubes ,,soo,,I am letting youall Know about this,, whom may come across this in the future,, Icon_crazy Icon_clap CHEERS
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 8166 online users. [Complete List]
» 1 Member(s) | 8165 Guest(s)
